[GRASS-user] v.in.ogr weird import
Christian Ferreira
chris.for.lists at googlemail.com
Mon Jul 7 11:29:55 EDT 2008
I tried many times to import some vectors into GRASS 6.2.2 and 6.3
using v.in.ogr.
The problem is... my location use Latitude-Longitude, and I tried use
the flag -o, but my vectors (once imported) always show now UTM
projection(?) (see below), but they are in fact, also
Latitude-Longitude (+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs)
as my region.
And the layer extent is: xMin,yMin -80.817,-10.6663 : xMax,yMax
-78.7871,-9.05281 (info from QGIS)
PS: to import raster data there was no problem.
PS: the command was: v.in.ogr -o
dsn=/home/poseidon/Work/vector_data/Tracklines2.shp output=tracklines2
min_area=0.0001 snap=-1
| Layer: tracklines2 at poseidon |
| Mapset: poseidon |
| Database: /home/poseidon/grass |
| Title: |
| Map scale: 1:1 |
| Map format: native |
| Name of creator: poseidon |
| Organization: |
| Source date: Mon Jul 7 16:44:24 2008 |
| Type of Map: vector (level: 2) |
| Number of points: 0 Number of areas: 0 |
| Number of lines: 1 Number of islands: 0 |
| Number of boundaries: 0 Number of faces: 0 |
| Number of centroids: 0 Number of kernels: 0 |
| Map is 3D: 0
| Number of dblinks: 1
| Projection: UTM |
| N: 9:03:10.133353S S: 10:39:58.771218S |
| E: 78:47:13.733701W W: 80:49:01.374885W |
| Digitization threshold: 0
| Comments:
Can someone help me?
Best regards,
Christian
Christian Ferreira
Poseidon Linux team
http://sites.google.com/site/poseidonlinux/
