[GRASS-user] v.in.ogr weird import
Carlos "Guâno" Grohmann
carlos.grohmann at gmail.com
Mon Jul 7 11:35:15 EDT 2008
Christian, if you shapefiles and you region are with the same
projection/coordinate system, the -o flag is not necessary.
also, the "dsn" option must point to the _directory_ were your shps are. like:
v.in.ogr dsn=/home/poseidon/Work/vector_data/ output=tracklines2
layer=Tracklines2.shp min_area=0.0001 snap=-1
hope this helps
Carlos
On Mon, Jul 7, 2008 at 12:29, Christian Ferreira
<chris.for.lists at googlemail.com> wrote:
> Hi,
> I tried many times to import some vectors into GRASS 6.2.2 and 6.3
> using v.in.ogr.
> The problem is... my location use Latitude-Longitude, and I tried use
> the flag -o, but my vectors (once imported) always show now UTM
> projection(?) (see below), but they are in fact, also
> Latitude-Longitude (+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs)
> as my region.
> And the layer extent is: xMin,yMin -80.817,-10.6663 : xMax,yMax
> -78.7871,-9.05281 (info from QGIS)
> PS: to import raster data there was no problem.
> PS: the command was: v.in.ogr -o
> dsn=/home/poseidon/Work/vector_data/Tracklines2.shp output=tracklines2
> | Layer: tracklines2 at poseidon |
> | Mapset: poseidon |
> | Location: M77 |
> | Database: /home/poseidon/grass |
> | Title: |
> | Map scale: 1:1 |
> | Map format: native |
> | Name of creator: poseidon |
> | Organization: |
> | Source date: Mon Jul 7 16:44:24 2008 |
> | Type of Map: vector (level: 2) |
> | Number of points: 0 Number of areas: 0 |
> | Number of lines: 1 Number of islands: 0 |
> | Number of boundaries: 0 Number of faces: 0 |
> | Number of centroids: 0 Number of kernels: 0 |
> | Map is 3D: 0
> | Number of dblinks: 1
> | Projection: UTM |
> | N: 9:03:10.133353S S: 10:39:58.771218S |
> | E: 78:47:13.733701W W: 80:49:01.374885W |
> | Digitization threshold: 0
> | Comments:
> Can someone help me?
> Best regards,
> Christian
> Christian Ferreira
> Poseidon Linux team
> http://sites.google.com/site/poseidonlinux/
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
