[GRASS-user] how to control label size (v.lable)?
Rei Hayashi
rei.grass at gmail.com
Mon Jul 7 21:12:14 EDT 2008
Hi Moritz and Hamish,
Thank you for your quick response. Now, I think I got an idea of
v.label and d.labels in the GRASS. Now, I am struggling to export the
map with appropriate size of labels in TIFF or PNG format.
Rei Hayashi
On Fri, Jul 4, 2008 at 8:32 AM, Hamish <hamish_b at yahoo.com> wrote:
> Rei Hayashi:
>> I am using a v.label command (+ d.labels command) to
>> present county names in the states' maps. I have tried
>> two slightly different commands.
>> 1)v.label map=XXX type=centroid column=YYY labels=ZZZ fontsize=5 color=red
>> 2)v.label map=XXX type=centroid column=YYY labels=ZZZ size=5 color=red
>> Both commands resulted in presenting same label size.
> -what version of GRASS?
> -displayed with d.labels, gis.m GUI, or ps.map?
> -does the $MAPSET/paint/labels/$NAME text file look ok?
> -spearfish or NC dataset example?
> -"works for me"
>> Also, I run this commands for Alabama, Louisiana, Mississippi, New
>> Mexico, Arizona and Oregon. Somehow, the label size in Alabama and
>> Louisiana are same, but bigger than the labels in the rest of states.
>> Also, I tested different fontsize and size (i.e. 20), but the
>> result stayed same way that the label size is bigger in Alabama and
>> Louisiana than other rest of the states.
> size= option is scale dependent, change the zoom, the text size changes.
> fontsize= is fixed.
> Hamish
