[GRASS-user] v.in.ogr weird import
Moritz Lennert
mlennert at club.worldonline.be
Tue Jul 8 10:29:48 EDT 2008
On 07/07/08 17:29, Christian Ferreira wrote:
> Hi,
> I tried many times to import some vectors into GRASS 6.2.2 and 6.3
> using v.in.ogr.
> The problem is... my location use Latitude-Longitude, and I tried use
> the flag -o, but my vectors (once imported) always show now UTM
> projection(?) (see below), but they are in fact, also
> Latitude-Longitude (+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs)
> as my region.
> And the layer extent is: xMin,yMin -80.817,-10.6663 : xMax,yMax
> -78.7871,-9.05281 (info from QGIS)
> PS: to import raster data there was no problem.
> PS: the command was: v.in.ogr -o
> dsn=/home/poseidon/Work/vector_data/Tracklines2.shp output=tracklines2
> min_area=0.0001 snap=-1
> | Layer: tracklines2 at poseidon |
> | Mapset: poseidon |
> | Location: M77 |
> | Database: /home/poseidon/grass |
> | Title: |
> | Map scale: 1:1 |
> | Map format: native |
> | Name of creator: poseidon |
> | Organization: |
> | Source date: Mon Jul 7 16:44:24 2008 |
> | Type of Map: vector (level: 2) |
> | Number of points: 0 Number of areas: 0 |
> | Number of lines: 1 Number of islands: 0 |
> | Number of boundaries: 0 Number of faces: 0 |
> | Number of centroids: 0 Number of kernels: 0 |
> | Map is 3D: 0
> | Number of dblinks: 1
> | Projection: UTM |
> | N: 9:03:10.133353S S: 10:39:58.771218S |
> | E: 78:47:13.733701W W: 80:49:01.374885W |
> | Digitization threshold: 0
> | Comments:
> Can someone help me?
What does g.proj -p show ?
Are the shapefiles accompanied by .prj files ?
Moritz
