[GRASS-user] Trouble with gdal/ogr grass plugin
John Overton
jd3 at renci.org
Tue Jul 8 15:44:02 EDT 2008
Hello,
I am having trouble getting the grass plugin for gdal/ogr to work. I
ultimately want to get Mapserver and GRASS working together and I am
getting stopped at this step. When I run
ogrinfo -ro on some of the spearfish vector data I get
FAILURE:
Unable to open datasource
`/home/jd3/grassdata/spearfish60/PERMANENT/vector/tracts' with the
following drivers.
-> GRASS
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> DGN
-> VRT
-> REC
-> Memory
-> BNA
-> CSV
-> GML
-> GPX
-> KML
-> GeoJSON
-> GMT
-> PostgreSQL
-> AVCBin
I use the full path, and I made sure the dirs are all readable.
I built all of the components from source.
I am working with GRASS 6.2.3
First I built GDAL version 1.5.1 using --without-grass
Then I built gdal-grass-1.4.3 configuring it like this ./configure
--with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/local/grass-6.2.3
The gdal and ogr grass plugins were installed in /usr/local/lib/gdalplugins
When I do gdal_translate --formats, I do indeed see the plugin
-bash-3.00$ gdal_translate --formats
Supported Formats:
GRASS (ro): GRASS Database Rasters (5.7+)
VRT (rw+): Virtual Raster ...
Using gdal on the GRASS raster formats gives a similar error.
When I try to access the GRASS data through Mapserver I get :
msDrawMap(): Image handling error. Failed to draw layer named 'Example2'.
msOGRFileOpen(): OGR error. Open failed for OGR connection
`/home/jd3/grassdata/spearfish60/PERMANENT/vector/t_tracts'. File not
found or unsupported format.
This is the Mapserver I am working with
-bash-3.00$ ./mapserv -v
MapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SW
F OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CL
IENT SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=TIFF
INPUT=E
PPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Could all this be due to a mismatch of versions between GDAL and GRASS?
I have made sure that I am indeed calling the versions that I think I am
by using the command 'which'.
Ultimately, I want to display GRASS data in a web interface. Any
suggestions would be greatly appreciated.
Thanks,
John David Overton
