[GRASS-user] Trouble with gdal/ogr grass plugin
Otto Dassau
otto.dassau at gmx.de
Tue Jul 8 16:07:33 EDT 2008
On Tue, 08 Jul 2008 15:44:02 -0400
John Overton <jd3 at renci.org> wrote:
> Hello,
> I am having trouble getting the grass plugin for gdal/ogr to work. I
> ultimately want to get Mapserver and GRASS working together and I am
> getting stopped at this step. When I run
> ogrinfo -ro on some of the spearfish vector data I get
> FAILURE:
> Unable to open datasource
> `/home/jd3/grassdata/spearfish60/PERMANENT/vector/tracts' with the
> following drivers.
try ogrinfo -ro /home/jd3/grassdata/spearfish60/PERMANENT/vector/tracts/head
and
gdalinfo /home/jd3/grassdata/spearfish60/PERMANENT/cellhd/<mapname>
that should work.
regards,
Otto
> -> GRASS
> -> ESRI Shapefile
> -> MapInfo File
> -> UK .NTF
> -> SDTS
> -> TIGER
> -> S57
> -> DGN
> -> VRT
> -> REC
> -> Memory
> -> BNA
> -> CSV
> -> GML
> -> GPX
> -> KML
> -> GeoJSON
> -> GMT
> -> PostgreSQL
> -> AVCBin
> I use the full path, and I made sure the dirs are all readable.
> I built all of the components from source.
> I am working with GRASS 6.2.3
> First I built GDAL version 1.5.1 using --without-grass
> Then I built gdal-grass-1.4.3 configuring it like this ./configure
> --with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/local/grass-6.2.3
> The gdal and ogr grass plugins were installed in /usr/local/lib/gdalplugins
> When I do gdal_translate --formats, I do indeed see the plugin
> -bash-3.00$ gdal_translate --formats
> Supported Formats:
> GRASS (ro): GRASS Database Rasters (5.7+)
> VRT (rw+): Virtual Raster ...
> Using gdal on the GRASS raster formats gives a similar error.
> When I try to access the GRASS data through Mapserver I get :
> msDrawMap(): Image handling error. Failed to draw layer named 'Example2'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection
> `/home/jd3/grassdata/spearfish60/PERMANENT/vector/t_tracts'. File not
> found or unsupported format.
> This is the Mapserver I am working with
> -bash-3.00$ ./mapserv -v
> MapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SW
> F OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CL
> IENT SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=TIFF
> INPUT=E
> PPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Could all this be due to a mismatch of versions between GDAL and GRASS?
> I have made sure that I am indeed calling the versions that I think I am
> by using the command 'which'.
> Ultimately, I want to display GRASS data in a web interface. Any
> suggestions would be greatly appreciated.
> Thanks,
> John David Overton
