[GRASS-user] Determining maximum value of attributes where areas
are overlapping in imported vector layer
Rainer M Krug
r.m.krug at gmail.com
Wed Jul 9 06:45:56 EDT 2008
On Wed, Jul 9, 2008 at 12:30 PM, G. Allegri <giohappy at gmail.com> wrote:
> It's not clear to me your situation...
> You have a singol vector layer with overlapping polygons? Did you
> import it as Level 1 (non-topological)?
I imported it with
v.in.ogr dsn=inputDir layer=fireHistory output=fireHistory --overwrite
and I get at the end the following warning:
WARNING: 703 areas represent more (overlapping) features, because polygons
overlap in input layer(s). Such areas are linked to more than 1
row in attribute table. The number of features for those areas is
stored as category in layer 2
225 input polygons
Total area: 2.033213e+08 (1220 areas)
Overlapping area: 6.822353e+07 (703 areas)
Area without category: 1.267486e+06 (65 areas)
What I want is to
a) identify these areas which have overlapping features (done via
layer 2) and identify how many features overlap (also done, see
http://grass.osgeo.org/wiki/Vector_Overlapping_Areas)
b) Get the maximum value of the field YEAR in the attribute table for
each feature
> 2008/7/9 Rainer M Krug <r.m.krug at gmail.com>:
>> On Tue, Jul 8, 2008 at 6:34 PM, Moritz Lennert
>> <mlennert at club.worldonline.be> wrote:
>>> On 08/07/08 18:14, Rainer M Krug wrote:
>>>> On Tue, Jul 8, 2008 at 4:21 PM, Moritz Lennert
>>>>> On 08/07/08 15:33, Rainer M Krug wrote:
>>>>>> On Tue, Jul 8, 2008 at 3:19 PM, Moritz Lennert
>>>>>>> On 08/07/08 15:02, Rainer M Krug wrote:
>>>>>>>> On Tue, Jul 8, 2008 at 10:25 AM, Rainer M Krug <r.m.krug at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Mon, Jul 7, 2008 at 9:37 PM, Markus Neteler <neteler at osgeo.org>
>>>>>>>>> wrote:
>>>>>>>>>> On Mon, Jul 7, 2008 at 6:28 PM, Rainer M Krug <r.m.krug at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> On Mon, Jul 7, 2008 at 6:19 PM, Markus Neteler <neteler at osgeo.org>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> On Mon, Jul 7, 2008 at 6:11 PM, Rainer M Krug <r.m.krug at gmail.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Hi
>>>>>>>>>>>>> I am back with a problem of imported shape files:
>>>>>>>>>>>>> I have imported a shape file and it contains several areas where
>>>>>>>>>>>>> polygons are overlapping. After I managed to obtain the number of
>>>>>>>>>>>>> overlapping polygons and exported it to a raster layer
>>>>>>>>>>>>> (http://grass.osgeo.org/wiki/Vector_Overlapping_Areas), I would
>>>>>>>>>>>>> now
>>>>>>>>>>>>> need the maximum value of an attribute column for this areas.
>>>>>>>>>>>>> Any ideas how I can achieve this?
>>>>>>>>>>>> You can use 'db.select':
>>>>>>>>>>>> echo "SELECT max(N1) FROM lidar2" | db.select
>>>>>>>>>>>> max(N1)
>>>>>>>>>>>> 512834.76000000000931
>>>>>>>>>>> Sorry for not being spoecific enough - I want the maximum values as
>>>>>>>>>>> ributes in an attribute table.
>>>>>>>>>>> As far as I can see, this just gives me the maximum value of the
>>>>>>>>>>> whole
>>>>>>>>>>> table - but I need it spatially, i.e. for each area which is
>>>>>>>>>>> overlapping, the maximum value.
>>>>>>>>>> Then v.to.db might be helpful.
>>>>>>>>>> http://grass.osgeo.org/grass64/manuals/html64_user/v.to.db.html
>>>>>>>>>> -> see qcolumn parameter.
>>>>>>>>> Thanks - tha is working now.
>>>>>>>> I was to fast - it is not working.
>>>>>>>> The reason is the following: if a small polygon A with YEAR=2006 is
>>>>>>>> completely overlapping with a larger polygon B with YEAR=2000,
>>>>>>>> max(YEAR) returns 2006 for the whole of polygon B - which is not what
>>>>>>>> I want. I would like to have 2006 for polygon A and 200 for polygon B,
>>>>>>>> except of the are where it overlaps with polygon A.
>>>>>>>> Any ideas on how to achieve this?
>>>>>>> v.overlay + v.to.db ?
>>>>>> I thought the same, but when I do v.overlay, it only takes one value
>>>>>> per polygon over to the new layer. If I could specify the max(YEAR)
>>>>>> query to choose the value, that would be the solution. Just look at
>>>>>> http://grass.osgeo.org/wiki/Vector_Overlapping_Areas - I used the
>>>>>> second solution for the count of the layers per location - but I don;t
>>>>>> have an ide to do it for max(YEAR)
>>>>> Not sure I understand. v.overlay operator=or should create new entities
>>>>> which are (to use your example): a piece of polygon A where there is only
>>>>> polygon A, a piece of polygon B where there is only polygon B and the
>>>>> common
>>>>> area between the two. In the table, you should then have the columns of
>>>>> both
>>>>> (a_cat, b_cat and a_YEAR, b_YEAR, etc) some of which will be null where
>>>>> you
>>>>> only have one of the two polygons. You can then query this table with
>>>>> something like this:
>>>>> select a_YEAR ... where b_YEAR is null or a_YEAR<b_YEAR
>>>> Yes, that is right. It seems to be working for two overlapping
>>>> polygons, but as soom as I have three overlapping polygons, I only get
>>>> two YEARS back (a_YEAR and b_YEAR - as the overlay is done between two
>>>> maps)
>>> Well, can't you then do a second overlay with the result of the first + the
>>> third layer of polygons ?
>> There seems to be still a misunderstanding, as all the polygons are in
>> the same grass vector layer and if I overlay the first overlay again
>> with the original layer, I the value of b_YEAR just becomes repeated.
>> I will see that I construct a simple example and post it here.
>> Thanks
>> Rainer
>>> Moritz
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Plant Conservation Unit
>> Department of Botany
>> University of Cape Town
>> Rondebosch 7701
>> South AfricaWARNING: 703 areas represent more (overlapping) features, because polygons
225 input polygons
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Rondebosch 7701
South Africa
