[GRASS-user] v.out.ogr multiple
Gabriele N.
gis.gn at libero.it
Wed Jul 9 07:26:11 EDT 2008
Thanks Moritz.
I have made some improvements.
I give you an example and the new script. Now I export all vectors with
name that starts with "foglio_1"
But I do not know how to select a folder where to export the shapes. Now,
only works if I enter the path by hand or select from a graphical user
interface a file in the folder (prova).
But it begins to work :-)
Still suggestions?
Thanks
Gabriele
http://www.nabble.com/file/p18359390/Schermata-v.out.ogr_multiplo.sh.png
http://www.nabble.com/file/p18359390/v.out.ogr_multiplo.sh
Moritz Lennert-2 wrote:
> On 09/07/08 10:42, Gabriele N. wrote:
>> Hi Moritz.
>>> On 08/07/08 22:33, Gabriele N. wrote:
>>>> Hello.
>>>> I want to create a script bash (GUI) to export many vector in shapefile
>>>> having the opportunity to decide which export layer (0, 1, 2) and
>>>> type=line,area ecc..
>>> Does this mean interactive decision layer by layer, or that the module
>>> should allow for entering layer and type as an option ?
>>>> I would also like to know if you can use the characters as' * 'to be
>>>> able
>>>> to
>>>> export all instance vector starting with' nome_vector ....'.
>>>> There is already some scripts? If not, I started to write something in
>>>> bash
>>>> but I am in difficulty.
>>> It will have to be something like:
>>> for map in `g.mlist type=vect pattern=$GIS_OPT_PATTERN
>>> do
>>> v.out.ogr $map type=$GIS_OPT_TYPE layer=$GIS_OPT_LAYER
>>> done
>>> where GIS_OPT_PATTERN would be something like 'nome_vector*'
>>> If you need to automatically decide which layers and types to export,
>>> you might be able to do some grep/awk magic with v.category -g $map
>>> option=report.
>>> Moritz
>>> grass-user mailing list
>>> grass-user a lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> I would like to insert layer and type as an option.
>> Attached is what I have done (GUI and script). However, there are errors.
>> http://www.nabble.com/file/p18356967/Schermata-v.out.ogr_multiplo.sh.png
>> http://www.nabble.com/file/p18356967/v.out.ogr_multiplo.sh
>> Where I wrong?
> It would be easier to help you if you gave us more information about the
> errors...
> But from looking at your script, I already see this:
> for map in g.mlist type=vect pattern=$GIS_OPT_PATTERN
> should be:
> for map in `g.mlist type=vect pattern=$GIS_OPT_PATTERN`
> note the backticks (`)
> and then
> v.out.ogr input=${map} ...
> should be v.out.ogr input=$map
> Moritz
> Moritz
View this message in context: http://www.nabble.com/v.out.ogr-multiple-tp18348459p18359390.html
Sent from the Grass - Users mailing list archive at Nabble.com.
