[GRASS-user] Grass/GMT problem
Roger Mason
rmason at esd.mun.ca
Wed Jul 9 08:26:23 EDT 2008
Hello,
I'm using the following to generate fake landscapes to be contoured in
GMT:
r.surf.fractal out="landscape"
r.rescale input="landscape" output="rescaled" to=0.0,30.1 --o
r.neighbors input="rescaled" output="smoothed" size=25 --o
r.out.bin -h input=smoothed output=gmt.grd --o
I set up gmt as follows:
psbasemap -JX10 -R0/100/0/100 -P -B -K -U"Contour Map" > map.ps
and invoke gmt's contour command thus:
grdcontour gmt.grd=bf -D -M -J -C5 -A5 -Gd3c -Wa2ta -O -K >> map.ps
The problem is that the produced "map" consists of very small, closed
loops that bear no resemblance to the landscape. You may ask how I
know what the landscape should look like. If I export the raster as
integer values, and import into into GMT using 'grdcontour gmt.grd=bf'
then everything is fine. I have tried r.out.gdal with the GMT and
netCDF types but the resulting files could not be read by grdcontour.
At the moment I don't know how to determine whether it is Grass, GMT
or my ineptitude that is the problem.
Thanks for any help.
Roger
Grass 6.3.0
GMT 4.1.1
Gentoo Linux
