[GRASS-user] Importing .tiff values
Moritz Lennert
mlennert at club.worldonline.be
Thu Jul 10 06:35:41 EDT 2008
On 10/07/08 11:05, Jana K. wrote:
> Hello, could someone help me, please? I am rather new in grass, so far
> I've succeeded making basic operations like creating locations, mapsets,
> importing maps, converting projections, etc. I have downloaded european
> landuse file which is in TIFF format. Unzipping produced several files,
> besides the .tiff, with these extensions: .tfw, .aux, .tif.xml, .prj and
> a .xls file containing a legend. Data in the map are categorical, the
> legend contains reference of each category to a particular r:g:b color
> in the map. I successfully imported the map to a new location, where I
> set projection manually using the g.setproj, using info in .prj file. I
> displayed the map and it seemed OK. Now, HERE IS MY PROBLEM: I used
> r.cats to find out what are the categories in the raster file resulting
> from the .tiff import. It gave me 44 categories from 1 to 44, apparently
> with no labels attached. I suppose the labels need to be attached
> somehow manually, although I don't know how yet.
r.category
or
r.support
> However, the bigger
> problem seems to be the fact that the .xls legend file contains r:g:b
> values and I don't know how to attach them to the 44 categories to the
> 44 r:g:b values in the .xls legend file. MY QUESTIONS: Is there a way in
> grass to get information on which color corresponds to which category?
r.colors with rules=
If you want to use the xls legend file, you will have to transform its
content to a text file in r.colors format, i.e. something like this:
0 255:255:255
2 255:255:0
5 0:255:0
Depending on the way you .xls file is structured this should be a more
or less painless export to space seperated text...
> How does r.in.ogr use the info contained in files other than .tiff,
> .tfw, coming in the bundle, or does it use it at all?
No, AFAIK, it only uses the tiff and tfw files. I think you should be
able to create a location with the correct projection system by using
"Create new location by ... georeferenced file" and pointing it to the
.prj file, but am not sure.
Moritz
