[GRASS-user] mapcalc and cell coordinates
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Jul 14 06:12:59 EDT 2008
On Mon, 14 Jul 2008, G. Allegri wrote:
> How can I control mapalgebra "if" statements on the base of the
> coordinates values of a cell?
> The base problem is to change the values of some specific cells on the
> base of their coordinates.
I suspect this might not be possible with r.mapcalc, because each
variable in an r.mapcalc expression is effectively an entire map and the
expression used to generate the output map can't be changed based on the
co-ordinates of individual cells in the input map. I.e., the same
expression applies to each and every cell in the output map.
That's my understanding anyway, based on an answer Glynn gave me a few
years ago:
http://lists.osgeo.org/pipermail/grass-user/2003-January/008182.html
Does that seem relevant to your case?
Paul
