[GRASS-user] mapcalc and cell coordinates
G. Allegri giohappy at gmail.com
Mon Jul 14 06:17:54 EDT 2008
Yer, but as mapcalc has some built-in functions like x() and y() to
retrieve the x-y coordinates, I think it could be easy to trasform
them in projected coordinates.
I'm writing a few lines in C to solve it, but I think I'll take a look
to r.mapcalc code to see if it would be possible to add something like
x_coord() and y_coord()...
2008/7/14 Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> On Mon, 14 Jul 2008, G. Allegri wrote:
>> How can I control mapalgebra "if" statements on the base of the
>> coordinates values of a cell?
>> The base problem is to change the values of some specific cells on the
>> base of their coordinates.
> I suspect this might not be possible with r.mapcalc, because each variable
> in an r.mapcalc expression is effectively an entire map and the expression
> used to generate the output map can't be changed based on the co-ordinates
> of individual cells in the input map. I.e., the same expression applies to
> each and every cell in the output map.
> That's my understanding anyway, based on an answer Glynn gave me a few years
> ago:
> http://lists.osgeo.org/pipermail/grass-user/2003-January/008182.html
> Does that seem relevant to your case?
> Paul
