[GRASS-user] building grass6.3.x testing version
Martin Landa landa.martin at gmail.com
Mon Jul 14 10:02:20 EDT 2008
BTW, building GRASS from the source I would recommend you to use
grass64 rather than grass63...
http://trac.osgeo.org/grass/wiki/DownloadSource#GRASS6.4
Martin
2008/7/14 G. Allegri <giohappy at gmail.com>:
> This is what Martin is referring to:
> $ sudo ln -s `locate _gdi_.so` /usr/local/lib/libgdi.so
> e.g.
> $ sudo ln -s /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so
> 2008/7/14 Martin Landa <landa.martin at gmail.com>:
>> Hi,
>>> The last two errors (wxpython and nviz) should be checked "making" rom
>>> inside the respective folders. Go into gui/wxpython/vdigit and
>>> visualization/nviz and try to compile.
>> Error in gui/wxpython/vdigit is probably connected to the missing
>> libgdi link (need to be solved for 6.4 release)
>> http://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README
>> -> 7 - VECTOR DIGITIZER
>> Martin
>> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
