[GRASS-user] building grass6.3.x testing version
Salvator*eL*arosa s_larosa at libero.it
Mon Jul 14 10:24:35 EDT 2008
Martin Landa-2 wrote:
> Hi,
> BTW, building GRASS from the source I would recommend you to use
> grass64 rather than grass63...
> http://trac.osgeo.org/grass/wiki/DownloadSource#GRASS6.4
> Martin
> 2008/7/14 G. Allegri <giohappy at gmail.com>:
>> This is what Martin is referring to:
>> $ sudo ln -s `locate _gdi_.so` /usr/local/lib/libgdi.so
>> e.g.
>> $ sudo ln -s
>> /usr/lib/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_gdi_.so
>> 2008/7/14 Martin Landa <landa.martin at gmail.com>:
>>> Hi,
>>>> The last two errors (wxpython and nviz) should be checked "making" rom
>>>> inside the respective folders. Go into gui/wxpython/vdigit and
>>>> visualization/nviz and try to compile.
>>> Error in gui/wxpython/vdigit is probably connected to the missing
>>> libgdi link (need to be solved for 6.4 release)
>>> http://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README
>>> -> 7 - VECTOR DIGITIZER
>>> Martin
>>> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Then try with 6.4, however, after the symlink,
doing make in gui/wxpython/vdigit gives me:
gcc: OBJ.i686-pc-linux-gnu/cats.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/digit.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/driver.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/line.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/select.o: No such file or directory
gcc: OBJ.i686-pc-linux-gnu/vertex.o: No such file or directory
make: *** [OBJ.i686-pc-linux-gnu/_grass6_wxvdigit.so] Error 1
I also added /usr/local/lib/ in my ld.so.conf and then
ldconfig i get the same error!
thanks
Salvatore Larosa
GPG: 0xE504BBE2 (FP: D9B2 CA87 81CD 1B91 E24D 3B42 D0F7 FA01 E504 BBE2)
View this message in context: http://www.nabble.com/building-grass6.3.x-testing-version-tp18444141p18445026.html
Sent from the Grass - Users mailing list archive at Nabble.com.
