[GRASS-user] mapcalc and cell coordinates
Moritz Lennert mlennert at club.worldonline.be
Mon Jul 14 11:25:29 EDT 2008
On 14/07/08 15:14, Glynn Clements wrote:
> Moritz Lennert wrote:
>> Well, this works:
>> r.mapcalc brol3=if(y()<=9521600 && x()<=427000,1,null())
>> but this doesn't:
>> r.mapcalc brol3=if(y()==9521600 && x()==427000,1,null())
>> which raises the issue of precision of the coordinates...
> What are the region settings? Bear in mind that x() and y() return the
> coordinates of the cell's centre, not a corner.
Just for completeness: It is a cell map, but resolution was aligned on
bounds, so something like 1.9876 and 2.0045
When I set resolution to 2 and align bounds to resolution and then use
r.mapcalc brol3=if(y()==9521601 && x()==427001,1,null())
it works
whereas
doesn't. So clearly an issue of falling right on the center of the pixel.
> Also note that the calculation involves multiplying by the resolution.
You mean internally by mapcalc, or that I should include resolution into
the calculation ?
> If the resolution cannot be exactly represented as both a binary
> fraction and a decimal fraction, you will get rounding error.
That and/or hitting the cell center was probably the problem.
Thanks for your explanations.
Moritz
