[GRASS-user] mapcalc and cell coordinates
Tue Jul 15 00:17:30 EDT 2008
Moritz Lennert wrote:
> > Also note that the calculation involves multiplying by the resolution.
> You mean internally by mapcalc, or that I should include resolution into
> the calculation ?
Internally.
The point is that if you have e.g. a 100m x 100m square, and you set
rows = cols = 300, so each cell is 1/3rd of a metre, *all* of the cell
centres will suffer from rounding error, even when the row and column
are multiples of 6, as the calculation will multiply by (a binary
approximation to) 1/3, not divide by 3.
