[GRASS-user] Re: make a raster index in GRASS
G. Allegri
giohappy at gmail.com
Wed Jul 16 09:07:17 EDT 2008
In case you have compiled gdal with grass support you could access
grass rasters directly from gdaltindex, pointing to the cellhd files.
2008/7/16 Ivan Shmakov <ivan at theory.asu.ru>:
>>>>>> Jamie Adams <jaadfoo at gmail.com> writes:
> > Hello all, I'd like to generate a raster index polygon file, just
> > like gdaltindex does, but using GRASS rasters as input. Is there a
> > command I'm overlooking?
> It may depend on the goal, but v.in.region(1) may be of some
> use.
> > If not, any ideas on how to do this?
> Iterating over the set of rasters can be implemented using
> g.mlist(1) and the standard Shell `while' and `read' commands,
> like:
> $ g.mlist type=rast pattern=2008-\*-foo \
> | while read r ; do \
> : ... do something... ; \
> done
> And the vectors can be concatenated using v.patch(1), like:
> v.in.region output=tmp_vector
> v.patch -a output=resulting_vector input=tmp_vector
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
