[GRASS-user] dyld: Library not loaded
Dwight Needels
needels at translucida.com
Wed Jul 16 22:06:43 EDT 2008
on 7/11/08 12:03 PM, Dwight Needels at needels at translucida.com wrote:
> Hi all,
> I get an error when I try to run v.in.gpsbabel...
> v.in.gpsbabel -t input=/Users/dwight/t_Westfield.gpx output=Westfield
> format=gpx
> Loading Tracks from </Users/dwight/t_Westfield.gpx>...
> dyld: Library not loaded: /usr/lib/libexpat.1.dylib
> Referenced from: /Applications/GRASS-6.3.app/Contents/MacOS/bin/gpsbabel
> Reason: image not found
> /Applications/GRASS-6.3.app/Contents/MacOS/scripts/v.in.gpsbabel: line 283:
> 27874 Trace/BPT trap
> gpsbabel $TYPE -i $GIS_OPT_FORMAT $GPSdevice $PROGVERBOSE -o gpx -F "$TMP".gpx
> ERROR: Error loading data from gpsbabel
> I have done this in the past without any problem, but four things that have
> changed since the last time I tried are: (1) upgraded to GRASS version 6.3,
> (2) switched from Lorenzo¹s binary to William Kyngesburye¹s, (3) upgraded to
> GPSBabel 1.3.5 and (4) switched to use SQLite instead of DBF.
> From within a GRASS session, attempts to use gpsbabel to convert a track to a
> route fail with the same dyld: Library not loaded message, but not if I use an
> explicit path to my installed version of gpsbabel. It is in my PATH, and works
> fine if I run it from a fresh Terminal session. Does this mean it is an issue
> with gpsbabel within the GRASS package?
> Any ideas on how I can fix this?
> GRASS 6.3cvs
> gpsbabel 1.3.5
> Macintosh PPC
> MacOS X 10.4.11
> Thanks,
> -Dwight
Does anyone have any ideas for how I can get g.in.gpsbabel to work?
Thanks,
-Dwight
