[GRASS-user] dyld: Library not loaded
Dwight Needels needels at translucida.com
Thu Jul 17 23:17:33 EDT 2008
on 7/17/08 11:02 PM, William Kyngesburye at woklist at kyngchaos.com wrote:
> On Jul 17, 2008, at 9:38 PM, Dwight Needels wrote:
>> GRASS 6.3.0 (Meriden_GIS):~ > type gpsbabel
>> gpsbabel is hashed (/Applications/GRASS-6.3.app/Contents/MacOS/bin/
>> gpsbabel)
>> Thanks, -Dwight
> Huh?  I don't know what "hashed" means.  I don't get that on my
> Leopard GRASS.  I don't have Tiger handy to test.
> What about if you use the full path to the copy in my GRASS?
> Hmmm..... I wonder if my gpsbabel binary is f'd for Tiger...  AH!
> There's the problem!  Looks like I need to update my GRASS binary.
> With all the copies lying around for build/staging/installed, I
> checked the wrong one.
> Stay tuned for update...
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin]  You think you have problems?  What are you supposed to do if
> you ARE a maniacally depressed robot?  No, don't try and answer, I'm
> 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
William,
Just to confirm... same error with explicit path to your gpsbabel (I hadn't
tried that yet).
I will let you know how the next build works out.
Thanks!!
-Dwight
