[GRASS-user] Scalebar for lon/lat projection in ps.map
maning sambale
emmanuel.sambale at gmail.com
Sun Jul 20 21:18:37 EDT 2008
On 7/19/08, Hamish <hamish_b at yahoo.com> wrote:
> maning sambale wrote:
>> I am preparing a country-wide map using ps.map. The region spans 2-3
>> UTM zones although most of the region is covered by one zone but I
>> still need the data at the fringes covered in another zone.
>> In order to do that I used a lon/lat projection. However, ps.map
>> will not produce a scalebar for lon/lat projection for good reasons.
>> I know this isn't good practice. Any Ideas how I can
>> produce a "scalebar" for lon/lat?
> my advice is: don't. overlay a grid or geogrid instead. with at least
> two grid lines for both lat + long the reader can see the scale.
Thanks!
> you can reproject everything into the central UTM zone, but the outside
> parts may start to be distorted. if only going +/- 1 zone you may get away
> with it.
I followed this advice and used a central UTM zone.
> Hamish
| __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
| /'.-c |Linux registered user #402901, http://counter.li.org/ |
| | /T |http://esambale.wikispaces.com|
| _)_/LI
