[GRASS-user] Once more: raster projection transformation: LAEA
-> UTM
Maciej Sieczka
tutey at o2.pl
Wed Jul 23 08:07:14 EDT 2008
Glynn Clements pisze:
> You can correct the projection information (both in the DEFAULT_WIND
> and WIND files and the PROJ_INFO file)by running g.setproj, or by
> using "g.proj -c ..." without a location= argument.
Jana,
Right, I forgot about *WIND files. The "proj:" in them muct be in sync
with PROJ_INFO content. What Glynn suggests should help. But how did you
end up with PROJ_INFO and *WIND files not compatible?
Maciek
Maciej Sieczka
www.sieczka.org
