[GRASS-user] Once more: raster projection transformation: LAEA
-> UTM
Jana K.
jkrajc at gmail.com
Wed Jul 23 09:17:44 EDT 2008
Maciej Sieczka wrote:
> Glynn Clements pisze:
>> You can correct the projection information (both in the DEFAULT_WIND
>> and WIND files and the PROJ_INFO file)by running g.setproj, or by
>> using "g.proj -c ..." without a location= argument.
> Jana,
> Right, I forgot about *WIND files. The "proj:" in them muct be in sync
> with PROJ_INFO content. What Glynn suggests should help. But how did you
> end up with PROJ_INFO and *WIND files not compatible?
> Maciej, Glynn, you are right. The projection in WIND files was set to 0.
> Actually, I am not completely sure how I ended up with the inconsistency.
> I was almost sure that I created the location as described in my previous
> mail - so I have tried to reproduce it a little while ago, but it produced
> correct, consistent WIND and PROJ files.
> I must have made a mistake during the original location creation.
> Well, at least I have learned something :jumping:
> Thanks for help!
> Jana
View this message in context: http://www.nabble.com/Once-more%3A-raster-projection-transformation%3A-LAEA--%3E-UTM-tp18589640p18610536.html
Sent from the Grass - Users mailing list archive at Nabble.com.
