[GRASS-user] v.net option connect
Martin Landa landa.martin at gmail.com
Wed Jul 23 10:05:48 EDT 2008
Ciao Ivan,
2008/7/23 ivan marchesini <marchesini at unipg.it>:
> I have a network of 6379 roads
> I have a map with a single point
> I run:
> v.net input=road points=point operation=connect output=connected_point
> thresh=(very high thresh) alayer=1 nlayer=2
> then (to check the output):
> v.build connected_point
> and I see that the number of lines is 6381
> i.e. the module v.net creates two lines for one point???
the network arc(edge) need to be splitted, e.g.
In this case you get two lines more.
Cheers, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
