[GRASS-user] v.net option connect
ivan marchesini marchesini at unipg.it
Thu Jul 24 03:42:19 EDT 2008
oh....
yes...
I supposed it was a stupid question  :-)
Thanks... Martin...
ciao
Il giorno mer, 23/07/2008 alle 16.05 +0200, Martin Landa ha scritto:
> Ciao Ivan,
> 2008/7/23 ivan marchesini <marchesini at unipg.it>:
> > I have a network of 6379 roads
> > I have a map with a single point
> > I run:
> > v.net input=road points=point operation=connect output=connected_point
> > thresh=(very high thresh) alayer=1 nlayer=2
> > then (to check the output):
> > v.build connected_point
> > and I see that the number of lines is 6381
> > i.e. the module v.net creates two lines for one point???
> the network arc(edge) need to be splitted, e.g.
> In this case you get two lines more.
> Cheers, Martin
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73 at jabber.org
