[GRASS-user] creating contour maps from x,y.z data
Moritz Lennert
mlennert at club.worldonline.be
Wed Jul 23 10:52:56 EDT 2008
On 23/07/08 01:44, Tim Michelsen wrote:
> Hello,
> I found the python matplotlib basemap toolkit as an easy and fast tool
> to plot data from a xyz data file (regular spaced) as a contour map.
> For an online example see:
> http://matplotlib.sourceforge.net/screenshots.html
> What is the GRASS workflow to accomplish this?
> I dis:
> v.in.ascii my_xyz
> v.surf.idw
try
- v.surf.rst or r.surf.nnbathy (add-on).
- r.in.xyz
> But the result map was rather coarse with a lot of pixels
Try changing your resolution settings.
> and no
> definitive contours.
Did you run r.contour to create the contours ?
Moritz
