[GRASS-user] tips on GRASS Mac users
William Kyngesburye woklist at kyngchaos.com
Fri Jul 25 10:34:27 EDT 2008
On Jul 25, 2008, at 12:55 AM, maning sambale wrote:
> How to configure middle-click for the zooming function in GRASS with
> imacs mighty mouse?
GRASS (X11) takes mouse buttons as they are assigned in System
Preferences->Keyboard & Mouse.  ie, if you set your mouse right-
handed, the left and right will be switched in GRASS also.  I believe
the middle button on the mighty mouse defaults to some OS feature (I
don't have an iMac handy, but can check later), so you need to change
it to a normal middle button.
I think there's also a key you can use in GRASS to emulate a middle-
click but I can't find it in the docs.
Tip: disable the side squeeze buttons, I found that they are too
sensitive (unless recent models have improved), and when lifting the
mouse to recenter it on the mousepad it's easy to accidentally trigger
Exposé.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
