[GRASS-user] How to use SQLite command
SGW00412 at nifty.com SGW00412 at nifty.com
Fri Jul 25 21:22:29 EDT 2008
Dear all
Thank you useful advice.... but I failed.
I installed splite3 by using cygwin set up module.
After that, I check splite3 operation at command line.
> GRASS 6.3.0 (idokeido_japan):~ > sqlite3
> SQLite version 3.5.1
I made new mapset as follows:
g.mapset -c mapset=new_db location=idokeido_japan gisdbase='/home/shimada'
And I tried to connect... , but failed.
db.connect driver=sqlite database='home/shimada/idokeido_japan/new_db/sqlite.db'
......ERROR: value <sqlite> out of range for parameter <driver>
       Legal range: dbf,ogr,pg
GRASS 6.3.0 (idokeido_japan):~ > db.drivers -p
dbf
ogr
pg
Why ???
shimada
"Martin Landa" <landa.martin at gmail.com>‚³‚ñF
> Hi,
> 2008/7/25  <sgw00412 at nifty.com>:
> > I want to manage grass database with SQLite
> > So, I input following command from keyboard:
> > db.connect driver=sqlite database='gis/latlon_jpn/PERMANENT/sqlite.db'
> > Error: value <sqlite> out of range for parameter <driver>
> >       Legal range: dbf,ogr,pg....
> > Why error massage ?
> GRASS need to be compiled with sqlite support (--with-sqlite switch).
> You can check supported db drivers in your installation with
> db.drivers -p
> Regards, Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
