[GRASS-user] How to use SQLite command
SGW00412 at nifty.com
Sat Jul 26 02:16:21 EDT 2008
Hi
I understand these advice.
It need to rebuild or re-compile grass, I guess.
Thank you.
shimada
SGW00412 at nifty.com³ñF
> Dear all
> Thank you useful advice.... but I failed.
> I installed splite3 by using cygwin set up module.
> After that, I check splite3 operation at command line.
> > GRASS 6.3.0 (idokeido_japan):~ > sqlite3
> > SQLite version 3.5.1
> I made new mapset as follows:
> g.mapset -c mapset=new_db location=idokeido_japan gisdbase='/home/shimada'
> And I tried to connect... , but failed.
> db.connect driver=sqlite database='home/shimada/idokeido_japan/new_db/sqlite.
db'
> ......ERROR: value <sqlite> out of range for parameter <driver>
> Legal range: dbf,ogr,pg
> GRASS 6.3.0 (idokeido_japan):~ > db.drivers -p
> dbf
> ogr
> pg
> Why ???
> shimada
> "Martin Landa" <landa.martin at gmail.com>³ñF
> > Hi,
> > 2008/7/25 <sgw00412 at nifty.com>:
> > > I want to manage grass database with SQLite
> > > So, I input following command from keyboard:
> > > db.connect driver=sqlite database='gis/latlon_jpn/PERMANENT/sqlite.db'
> > > Error: value <sqlite> out of range for parameter <driver>
> > > Legal range: dbf,ogr,pg....
> > > Why error massage ?
> > GRASS need to be compiled with sqlite support (--with-sqlite switch).
> > You can check supported db drivers in your installation with
> > db.drivers -p
> > Regards, Martin
> > Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
