[GRASS-user] grass 6.3.0 solaris 10 install errors
Brian Clark brclark at usgs.gov
Thu Jul 31 18:41:10 EDT 2008
Glynn Clements wrote:
> Brian Clark wrote:
>> Thanks Glynn,
>> I'm finally getting back to this - more errors I'm afraid...
>>> 	make INSTALL=`pwd`/install-sh
>>> Also, the Makefile was setting incorrect permissions on install-sh
>>> (744 instead of 755), so it was only executable for the owner.
>> After chmod 755 install-sh
>> then make INSTALL=/wattemp/GRASS/grass-6.3.0/install-sh
>> I get a bunch of complaints like:
>> make[1]: *** No rule to make target `../include/Make/Dir.make'.  Stop.
> Does the file exist? If not, you need to extract the source code and
> try again. If you get similar errors, try to note the point at which
> they start.
Yes - it exists even after configure. Then it's gone after make - still
trying to track down exactly where during make.. and it only appears to
happen when i use make INSTALL=/wattemp/GRASS/grass-6.3.0/install-sh
versus simply 'make'
>> ideas on what I may have done wrong?
>> I also noticed that just before I tried make INSTALL, Platform.make did
>> exist in include/Make/
>> After the make, Platform.make.in existed, but not Platform.make.
> >From the errors, it looks as if something is deleting the include/Make
> directory or its contents.
