[GRASS-user] grass 6.3.0 solaris 10 install errors
Thu Jul 31 18:09:57 EDT 2008
Brian Clark wrote:
> Thanks Glynn,
> I'm finally getting back to this - more errors I'm afraid...
> > 	make INSTALL=`pwd`/install-sh
> > Also, the Makefile was setting incorrect permissions on install-sh
> > (744 instead of 755), so it was only executable for the owner.
> After chmod 755 install-sh
> then make INSTALL=/wattemp/GRASS/grass-6.3.0/install-sh
> I get a bunch of complaints like:
> make[1]: *** No rule to make target `../include/Make/Dir.make'.  Stop.
Does the file exist? If not, you need to extract the source code and
try again. If you get similar errors, try to note the point at which
they start.
> ideas on what I may have done wrong?
> I also noticed that just before I tried make INSTALL, Platform.make did
> exist in include/Make/
> After the make, Platform.make.in existed, but not Platform.make.
>From the errors, it looks as if something is deleting the include/Make
directory or its contents.
