[GRASS-user] grass 6.3.0 solaris 10 install errors
Brian Clark brclark at usgs.gov
Thu Jul 31 17:37:40 EDT 2008
Thanks Glynn,
I'm finally getting back to this - more errors I'm afraid...
Glynn Clements wrote:
> Brian Clark wrote:
>>> I suspect that lib/gis/Makefile needs $(SOCKLIB) added to EXTRA_LIBS:
>>> -EXTRA_LIBS = $(XDRLIB) $(DATETIMELIB) $(INTLLIB) $(MATHLIB)
>>> +EXTRA_LIBS = $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(INTLLIB) $(MATHLIB)
>> Thanks Glynn -
>> I changed the Makefile for lib/gis/, and moved on to next error....
>> first in the list was /lib/db/sqlp
>> ->make
>> mkdir -p /wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/docs/html
>> ../.././install-sh -c  -m 644 description.html
>> /wattemp/GRASS/grass-6.3.0/dist.sparc-sun-solaris2.10/docs/html/sql.html
>> make: ../.././install-sh: Command not found
> Ack. The way that autoconf handles the install-sh script is broken. It
> sets the INSTALL variable to a relative path, relative to the
> directory containing the file in which INSTALL is substituted.
> If you're generating each directory's Makefile from a Makefile.in,
> this works fine, but GRASS' Makefiles include these definitions from
> include/Make/Platform.make. So, configure defines INSTALL relative to
> include/Make/Platform.make, so it doesn't work if you are more or less
> than two levels deep.
> You can get around this by manually setting INSTALL to an absolute
> path, e.g.:
> 	make INSTALL=`pwd`/install-sh
> Also, the Makefile was setting incorrect permissions on install-sh
> (744 instead of 755), so it was only executable for the owner.
After chmod 755 install-sh
then make INSTALL=/wattemp/GRASS/grass-6.3.0/install-sh
I get a bunch of complaints like:
make[1]: *** No rule to make target `../include/Make/Dir.make'.  Stop.
make[1]: Leaving directory `/wattemp/GRASS/grass-6.3.0/sites'
make[1]: Entering directory `/wattemp/GRASS/grass-6.3.0/tools'
Makefile:5: ../include/Make/Dir.make: No such file or directory
make[1]: Leaving directory `/wattemp/GRASS/grass-6.3.0/tools'
make[1]: Entering directory `/wattemp/GRASS/grass-6.3.0/vector'
Makefile:73: ../include/Make/Platform.make: No such file or directory
Makefile:99: ../include/Make/Dir.make: No such file or directory
make[1]: Leaving directory `/wattemp/GRASS/grass-6.3.0/vector'
make[1]: Entering directory `/wattemp/GRASS/grass-6.3.0/visualization'
Makefile:8: ../include/Make/Platform.make: No such file or directory
Makefile:20: ../include/Make/Dir.make: No such file or directory
make[1]: Leaving directory `/wattemp/GRASS/grass-6.3.0/visualization'
make[1]: Entering directory `/wattemp/GRASS/grass-6.3.0/man'
Makefile:3: ../include/Make/Dir.make: No such file or directory
make[1]: Leaving directory `/wattemp/GRASS/grass-6.3.0/man'
make[1]: Entering directory `/wattemp/GRASS/grass-6.3.0/macosx'
Makefile:3: ../include/Make/Platform.make: No such file or directory
Makefile:33: ../include/Make/Dir.make: No such file or directory
make[1]: Leaving directory `/wattemp/GRASS/grass-6.3.0/macosx'
ideas on what I may have done wrong?
I also noticed that just before I tried make INSTALL, Platform.make did
exist in include/Make/
After the make, Platform.make.in existed, but not Platform.make.
thanks,
brc
