[GRASS-user] r.sun2: "Wh" or "kWh"?
Markus Neteler
neteler at osgeo.org
Thu Jun 5 03:37:03 EDT 2008
Here the authoritative answer:
On Thu, Jun 5, 2008 at 8:16 AM, Thomas Huld <Thomas.Huld at jrc.it> wrote:
>> <nikos.alexandris at felis.uni-freiburg.de> wrote:
>> > Dear list,
>> > in the file "description.html" of the module "r.sun2" under the section
>> > OPTIONS it is stated: In the second mode daily sums of solar irradiation
>> > [kWh.m-2.day-1] are computed for a specified day.
>> > Should it be [Wh.m-2.day-1] ?
> The documentation is wrong. As you all point out correctly, it should be
> Wh.m-2.day-1. Sorry for the confusion.
> Thomas
> Thomas Huld
> Joint Research Centre of the European Commission
> T.P. 450
> I-21023 Ispra, Italy
> phone: +39 0332785273
> e-mail: Thomas.Huld at jrc.it
I have fixed it in Addons-SVN:
[neteler at markus r.sun2]$ svn diff
Index: description.html
--- description.html (revision 31633)
+++ description.html (working copy)
@@ -137,7 +137,7 @@
<P>Currently, there are two modes of r.sun.
In the first mode it calculates solar incidence angle and solar irradiance
raster maps using the set local time. In the second mode daily sums of solar
-irradiation [kWh.m-2.day-1] are computed for a specified day. </p>
+irradiation [Wh.m-2.day-1] are computed for a specified day. </p>
Markus
