[GRASS-user] exploding a color table
Glynn Clements
glynn at gclements.plus.com
Thu Jun 5 21:09:29 EDT 2008
Neil Best wrote:
> Has anyone come up with a way to convert a streched color table for a
> floating point map into a set of discrete colors? I am thinking especially
> of NDVI, so I would like to generate the list of 256 colors along the NDVI
> floating point stretch to use with the result of r.recode that I used to
> convert my NDVI map to an integer map. If I could properly set the color
> table for that new map then I could maintain the symbolization within GRASS
> rather than having to spew a list of 256 colors for a Mapserver
> configuration. Any thoughts?
You can query the colour corresponding to specific values using
r.what.color.
