[GRASS-user] Re: updating from GRASS from svn Unable to locate
curses includes
Glynn Clements
glynn at gclements.plus.com
Wed Jun 11 00:28:46 EDT 2008
Hamish wrote:
> these instructions should help:
> http://grass.osgeo.org/wiki/Compile_and_Install#Platform_Specific_Notes
> one thing there I don't understand: it recommends to do:
> CFLAGS="-g" LDFLAGS="-s" ./configure
> -g adds debugging hooks, but -s strips away debug messages. ???
> (to quote tom waits: the large print giveth and the small print taketh away)
The LDFLAGS=-s part is bogus.
It used to be a common recommendation to counteract the fact that
configure defaults to "-g -O2" if the compiler is gcc. You wouldn't
use -s if you actually want the debug info.
Also, stripping the debug info is a false economy unless you're
seriously short of hard disk space. If you have your own PC (and it
doesn't belong in a museum), your disk space is likely to be measured
in hundreds of gigabytes, of which binaries (libraries and
executables) might account for around a gigabyte if *everything* is
built with debug info.
The only cases where stripping debug info makes sense is if you're
using a shared server with a miniscule quota, or if you're building a
binary distribution and you really need to minimise the size (FWIW, I
keep the debug info for the Cygwin packages).
For normal use, stick with "-g -O2". That produces optimised binaries
but keeps the debug info just in case you need to do minimal debugging
(e.g. make sense of a core file). If you want to actually debug the
program (set breakpoints, single step, examine variables etc), then
you need to drop the -O2, as it will result in object code which bears
little relation to the actual source code, and can only be debugged in
the most superficial sense.
