[GRASS-user] Re: updating from GRASS from svn Unable to locate curses includes
maning sambale emmanuel.sambale at gmail.com
Wed Jun 11 01:31:03 EDT 2008
Got it working now including the add-ons thanks to all your help.  It
seems the compile and install page says it all:
http://grass.osgeo.org/wiki/Compile_and_Install#Configure_options_and_their_meanings
I just need to understand how it works.
cheers,
maning
On Wed, Jun 11, 2008 at 1:05 PM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> Wohoo! Now it running.
> One last question, I have checked out from svn the grass-addons
> particularly the imagery.  How do I add them in the compilation?
> cheers,
> maning
> On Wed, Jun 11, 2008 at 12:28 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
>> Hamish wrote:
>>> these instructions should help:
>>> http://grass.osgeo.org/wiki/Compile_and_Install#Platform_Specific_Notes
>>> one thing there I don't understand: it recommends to do:
>>>   CFLAGS="-g" LDFLAGS="-s" ./configure
>>> -g adds debugging hooks, but -s strips away debug messages.  ???
>>> (to quote tom waits: the large print giveth and the small print taketh away)
>> The LDFLAGS=-s part is bogus.
>> It used to be a common recommendation to counteract the fact that
>> configure defaults to "-g -O2" if the compiler is gcc. You wouldn't
>> use -s if you actually want the debug info.
>> Also, stripping the debug info is a false economy unless you're
>> seriously short of hard disk space. If you have your own PC (and it
>> doesn't belong in a museum), your disk space is likely to be measured
>> in hundreds of gigabytes, of which binaries (libraries and
>> executables) might account for around a gigabyte if *everything* is
>> built with debug info.
>> The only cases where stripping debug info makes sense is if you're
>> using a shared server with a miniscule quota, or if you're building a
>> binary distribution and you really need to minimise the size (FWIW, I
>> keep the debug info for the Cygwin packages).
>> For normal use, stick with "-g -O2". That produces optimised binaries
>> but keeps the debug info just in case you need to do minimal debugging
>> (e.g. make sense of a core file). If you want to actually debug the
>> program (set breakpoints, single step, examine variables etc), then
>> you need to drop the -O2, as it will result in object code which bears
>> little relation to the actual source code, and can only be debugged in
>> the most superficial sense.
>> Glynn Clements <glynn at gclements.plus.com>
> | __.-._ |"Ohhh. Great warrior. Wars not make one great." -Yoda |
> | '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
> | /'.-c |Linux registered user #402901, http://counter.li.org/ |
> | | /T |http://esambale.wikispaces.com|
> | _)_/LI
| _)_/LI
