[GRASS-user] Strange v.to.points error
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Thu Jun 12 08:43:01 EDT 2008
On Thu, 2008-06-12 at 14:07 +0200, Jarosław Jasiewicz wrote:
> Martin Landa pisze:
> > Hi,
> > 2008/6/12 Jarosław Jasiewicz <jarekj at amu.edu.pl>:
> >> GRASS 6.3.svn (polska):~ > v.to.points -n input=mrog_vector output=zb_point
> >> type=point,line, llayer=1 dmax=100
> >> DBMI-Postgres driver error:
> >> Cannot select:
> >> select * from mrog_5 where 0 = 1
> >> ERROR: relation "mrog_5" does not exist
> >> Warning:Cannot open select cursor: 'select * from mrog_5 where 0 = 1'
> >> ERROR:Cannot copy table
> >> the input is mrog_vector
> >> error concerns completly different table, which realy don't exist
> > what
> > v.db.connect mrog_vector -p
> > says?
> > Probably you have accidently linked not existing table 'mrog_5' to the
> > vector map.
> > Martin
> v.db.connect -p says that no table is connected, in general I know
> nothing about mrog_5 I have never create it.
> adationally when I tried to add empty table the same message appear
> I remove the vector and import it again, I thing it was accident error
> due to some unknown circumstances, but why v.to.points became crazy?
Jarek,
you already where connected (using db.connect) while importing your
vector map in the GRASS' database?
Nikos
