[GRASS-user] Trouble with (gdalwarp) r.in.wms ubder Ubuntu 64bit
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat Jun 14 07:34:05 EDT 2008
[ I assume this has to again with variables, paths and similar in which
I still don't understand fully. Isn't there a way to set this by default
when installing GRASS (or gdaltools)? ]
Under Ubuntu64bit I get some trouble with r.in.gdal (actually gdalwarp):
r.in.wms mapserver="$SERVER" layer=UK500 out=UK500_Bavaria.3 format=tiff
Calculating tiles
Requesting 1 tiles.
Downloading tiles
Tile already downloaded
All tiles downloaded successfully
Creating output file that is 572P x 662L.
Processing input
file /home/nik/grassdb/rlp_fgaps/wms_download/UK500_Bavaria.3__0.tiff.
Using band 4 of source image as alpha.
Using band 4 of destination image as alpha.
0...10...20...30...40...50...60...70...80...90...100 - done.
*** glibc detected *** gdalwarp: double free or corruption (!prev):
0x0000000000611a10 ***
======= Backtrace: =========
/lib/libc.so.6[0x7f0c0a3f308a]
/lib/libc.so.6(cfree+0x8c)[0x7f0c0a3f6c1c]
/usr/lib/libgdal1.5.0.so.1(_ZN17GDALDriverManagerD0Ev
+0x49)[0x7f0c0b121cc9]
gdalwarp[0x403441]
/lib/libc.so.6(__libc_start_main+0xf4)[0x7f0c0a39d1c4]
gdalwarp(GDALTermProgress+0xa1)[0x402a39]
======= Memory map: ========
00400000-00407000 r-xp 00000000 08:06
1710513 /usr/bin/gdalwarp
00606000-00607000 rw-p 00006000 08:06
00607000-00698000 rw-p 00607000 00:00 0
[heap]
7f0bf8000000-7f0bf8021000 rw-p 7f0bf8000000 00:00 0
7f0bf8021000-7f0bfc000000 ---p 7f0bf8021000 00:00 0
7f0bff8ff000-7f0bffce8000 r-xp 00000000 08:06
1778199 /usr/lib/libxerces-c.so.27.0
7f0bffce8000-7f0bffee7000 ---p 003e9000 08:06
7f0bffee7000-7f0bfff2b000 rw-p 003e8000 08:06
7f0bfff2b000-7f0bfff2c000 rw-p 7f0bfff2b000 00:00 0
7f0bfff2c000-7f0bfffe3000 r-xp 00000000 08:06
1778128 /usr/lib/libfftw3.so.3.1.2
7f0bfffe3000-7f0c001e3000 ---p 000b7000 08:06
7f0c001e3000-7f0c001e9000 rw-p 000b7000 08:06
7f0c001e9000-7f0c00220000 r-xp 00000000 08:06
863332 /lib/libncurses.so.5.6
7f0c00220000-7f0c0041f000 ---p 00037000 08:06
7f0c0041f000-7f0c00424000 rw-p 00036000 08:06
7f0c00424000-7f0c0087d000 r-xp 00000000 08:06
1779769 /usr/lib/libgdal1.4.0.so.1.11.4
7f0c0087d000-7f0c00a7c000 ---p 00459000 08:06
7f0c00a7c000-7f0c00ae7000 rw-p 00458000 08:06
7f0c00ae7000-7f0c00b2c000 rw-p 7f0c00ae7000 00:00 0
7f0c00b2c000-7f0c00b2d000 r-xp 00000000 08:06
427966 /usr/local/grass-6.3.1svn/lib/libgrass_linkm.6.3.1svn.so
7f0c00b2d000-7f0c00d2d000 ---p 00001000 08:06
7f0c00d2d000-7f0c00d2e000 rw-p 00001000 08:06
7f0c00d2e000-7f0c00d34000 r-xp 00000000 08:06
427993 /usr/local/grass-6.3.1svn/lib/libgrass_rtree.6.3.1svn.so
7f0c00d34000-7f0c00f34000 ---p 00006000 08:06
7f0c00f34000-7f0c00f35000 rw-p 00006000 08:06
7f0c00f35000-7f0c00f4c000 r-xp 00000000 08:06
427988 /usr/local/grass-6.3.1svn/lib/libgrass_dig2.6.3.1svn.so
7f0c00f4c000-7f0c0114c000 ---p 00017000 08:06
7f0c0114c000-7f0c0114d000 rw-p 00017000 08:06
7f0c0114d000-7f0c0116d000 r-xp 00000000 08:06
427943 /usr/local/grass-6.3.1svn/lib/libgrass_dgl.6.3.1svn.so
7f0c0116d000-7f0c0136d000 ---p 00020000 08:06
7f0c0136d000-7f0c0136e000 rw-p 00020000 08:06
7f0c0136e000-7f0c01379000 r-xp 00000000 08:06
427952 /usr/local/grass-6.3.1svn/lib/libgrass_dbmiclient.6.3.1svn.so
7f0c01379000-7f0c01578000 ---p 0000b000 08:06
7f0c01578000-7f0c01579000 rw-p 0000a000 08:06
7f0c01579000-7f0c0158c000 r-xp 00000000 08:06
428010 /usr/local/grass-6.3.1svn/lib/libgrass_dbmibase.6.3.1svn.so
7f0c0158c000-7f0c0178c000 ---p 00013000 08:06
7f0c0178c000-7f0c0178d000 rw-p 00013000 08:06
7f0c0178d000-7f0c017cc000 r-xp 00000000 08:06
428028 /usr/local/grass-6.3.1svn/lib/libgrass_vect.6.3.1svn.so
7f0c017cc000-7f0c019cc000 ---p 0003f000 08:06
7f0c019cc000-7f0c019ce000 rw-p 0003f000 08:06
7f0c019ce000-7f0c019d7000 r-xp 00000000 08:06
428024 /usr/local/grass-6.3.1svn/lib/libgrass_gproj.6.3.1svn.so
7f0c019d7000-7f0c01bd7000 ---p 00009000 08:06
7f0c01bd7000-7f0c01bd8000 rw-p 00009000 08:06
7f0c01bd8000-7f0c01be1000 r-xp 00000000 08:06
427949 /usr/local/grass-6.3.1svn/lib/libgrass_datetime.6.3.1svn.so
7f0c01be1000-7f0c01de1000 ---p 00009000 08:06
7f0c01de1000-7f0c01de2000 rw-p 00009000 08:06
7f0c01de2000-7f0c01e48000 r-xp 00000000 08:06
427997 /usr/local/grass-6.3.1svn/lib/libgrass_gis.6.3.1svn.so
7f0c01e48000-7f0c02047000 ---p 00066000 08:06
7f0c02047000-7f0c0204a000 rw-p 00065000 08:06
7f0c0204a000-7f0c0204f000 rw-p 7f0c0204a000 00:00 0
7f0c0204f000-7f0c02057000 r-xp 00000000 08:06
428036 /usr/local/grass-6.3.1svn/lib/libgrass_gmath.6.3.1svn.so
7f0c02057000-7f0c02256000 ---p 00008000 08:06
7f0c02256000-7f0c02257000 rw-p 00007000 08:06
7f0c02257000-7f0c0225c000 r-xp 00000000 08:06
428026 /usr/local/grass-6.3.1svn/lib/libgrass_vask.6.3.1svn.so
7f0c0225c000-7f0c0245b000 ---p 00005000 08:06
7f0c0245b000-7f0c0245c000 rw-p 00004000 08:06
7f0c0245c000-7f0c0245d000 rw-p 7f0c0245c000 00:00 0
7f0c0245d000-7f0c0246c000 r-xp 00000000 08:06
428035 /usr/local/grass-6.3.1svn/lib/libgrass_I.6.3.1svn.so
7f0c0246c000-7f0c0266b000 ---p 0000f000 08:06
7f0c0266b000-7f0c0266c000 rw-p 0000e000 08:06
7f0c0266c000-7f0c02674000 r-xp 00000000 08:06
2105908 /usr/lib/gdalplugins/gdal_GRASS.so
7f0c02674000-7f0c02874000 ---p 00008000 08:06
7f0c02874000-7f0c02875000 rw-p 00008000 08:06
7f0c02875000-7f0c02878000 r-xp 00000000 08:06
863301 /lib/libgpg-error.so.0.3.0
7f0c02878000-7f0c02a77000 ---p 00003000 08:06
7f0c02a77000-7f0c02a78000 rw-p 00002000 08:06
7f0c02a78000-7f0c02ac4000 r-xp 00000000 08:06
863545 /lib/libgcrypt.so.11.2.3
7f0c02ac4000-7f0c02cc3000 ---p 0004c000 08:06
7f0c02cc3000-7f0c02cc6000 rw-p 0004b000 08:06
7f0c02cc6000-7f0c02cd6000 r-xp 00000000 08:06
1776946 /usr/lib/libtasn1.so.3.0.12
7f0c02cd6000-7f0c02ed5000 ---p 00010000 08:06
7f0c02ed5000-7f0c02ed6000 rw-p 0000f000 08:06
7f0c02ed6000-7f0c02eee000 r-xp 00000000 08:06
1777046 /usAborted
ERROR: r.in.gdalwarp: gdalwarp failure.
ERROR: Raster map <UK500_Bavaria.3> not found in current mapset
