[GRASS-user] Trouble with (gdalwarp) r.in.wms ubder Ubuntu 64bit
Hamish
hamish_b at yahoo.com
Sun Jun 15 04:14:33 EDT 2008
Nikos Alexandris wrote:
> [ I assume this has to again with variables, paths and
> similar in which I still don't understand fully. Isn't there a
> way to set this by default when installing GRASS (or gdaltools)? ]
I am not sure what you mean to set?
Did you compile/install gdal by hand or from distributed binary packages?
> Under Ubuntu64bit I get some trouble with r.in.gdal
> (actually gdalwarp):
> r.in.wms mapserver="$SERVER" layer=UK500
> out=UK500_Bavaria.3 format=tiff
> Calculating tiles
> Requesting 1 tiles.
> Downloading tiles
> Tile already downloaded
> All tiles downloaded successfully
> Creating output file that is 572P x 662L.
> Processing input
> file
> /home/nik/grassdb/rlp_fgaps/wms_download/UK500_Bavaria.3__0.tiff.
> Using band 4 of source image as alpha.
> Using band 4 of destination image as alpha.
> 0...10...20...30...40...50...60...70...80...90...100 -
> done.
> *** glibc detected *** gdalwarp: double free or corruption
> (!prev):
> 0x0000000000611a10 ***
this is a memory handling error in gdalwarp.
what version of GDAL?
you could try using gdalwarp by itself on the command line with the saved input file /home/nik/grassdb/rlp_fgaps/wms_download/UK500_Bavaria.3__0.tiff
and see how it goes? If that still fails, file a gdal bug.
> ======= Backtrace: =========
> /lib/libc.so.6[0x7f0c0a3f308a]
> /lib/libc.so.6(cfree+0x8c)[0x7f0c0a3f6c1c]
> /usr/lib/libgdal1.5.0.so.1(_ZN17GDALDriverManagerD0Ev
> +0x49)[0x7f0c0b121cc9]
> gdalwarp[0x403441]
> /lib/libc.so.6(__libc_start_main+0xf4)[0x7f0c0a39d1c4]
> gdalwarp(GDALTermProgress+0xa1)[0x402a39]
(don't know)
> ERROR: r.in.gdalwarp: gdalwarp failure.
> ERROR: Raster map <UK500_Bavaria.3> not found in
> current mapset
currently in r.in.wms I don't know how to test to see if r.in.gdalwarp failed (it is called with eval), and so the r.in.wms script continues on as if it always works.
Hamish
