[GRASS-user] Trouble with v.in.ascii (x2) and v.out.ogr
Hamish
hamish_b at yahoo.com
Wed Jun 18 13:48:59 EDT 2008
> > Paulo Marcondes wrote:
> >> I had issues while triyng to import an ASCII
> >> vector file,
Hamish:
> > missing a centroid?
> I thought v.build would fix that for me.
> So I have do add by hand?
use v.centroids or v.category
> Also, where does a centroid goes, I mean, any point inside
> the boundary, or some other specific place?
any point inside the boundary.
> > you need to use v.in.ascii's
> "format=standard" if data is given in that form.
> You are right with regards to the standard format, the name
> is a bit misleading.
descriptions now updated in SVN to be more descriptive.
> >> When I imported (almost) the same ASCII file with
> >> r.in.xyz, somewhere in the northern part of the raster I
> >> got a blank E-W line, that I feel has something to do with
> >> that resolution difference (99.97 vs 100m)
> > probably that is correct, caused by a partial Moiré
> > effect.
> > adjust the res to be exactly 100 by expanding the
> > bounds of the region with "g.region res=100 -a".
> It works!
> Raster loaded beautifully.
cool bananas.
Hamish
