[GRASS-user] import multiple shapefiles automatically
Barbosa, A. Marcia a.m.barbosa at imperial.ac.uk
Thu Jun 19 08:26:18 EDT 2008
Another beginner's question. I need to import big groups of shapefiles to GRASS. So far I'm using
v.in.ogr 'dsn=C:/QGIS/species_shapefiles/XXX.shp' output=XXX -o
and replacing the names of the shapefiles by hand in each command line. But is there a way to tell GRASS to import all the shapefiles in a certain folder (I've tried *.shp but it didn't work), and give each output map the same name as the original shapefile?
Cheers,
Márcia
A. Márcia Barbosa
Dept. Biological Sciences, North 2.1
Imperial College at Silwood Park
Ascot, Berkshire SL5 7PY
United Kingdom
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080619/19b1f7a0/attachment.html
