R: [GRASS-user] import multiple shapefiles automatically
marco.pasetti at alice.it
Thu Jun 19 08:30:45 EDT 2008
>is there a way to tell GRASS to import all the shapefiles in a certain folder (I've tried *.shp but it didn't work), and give each output map the same name as the original shapefile?
v.in.ogr 'dsn=C:\QGIS\species_shapefiles'
If the layer parameter is not given, all available layers are imported (simply taken from the command description)
Marco
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080619/57cf3357/attachment.html
