[GRASS-user] import multiple shapefiles automatically
Christian Schwartze
Christian.Schwartze at uni-jena.de
Thu Jun 19 08:35:25 EDT 2008
HI,
use parameter dsn to specify only the folder of your shape files and ignore the
layer param.
Regards,
Christian.
Zitat von "Barbosa, A. Marcia" <a.m.barbosa at imperial.ac.uk>:
> Hi,
> Another beginner's question. I need to import big groups of shapefiles to
> GRASS. So far I'm using
> v.in.ogr 'dsn=C:/QGIS/species_shapefiles/XXX.shp' output=XXX -o
> and replacing the names of the shapefiles by hand in each command line. But
> is there a way to tell GRASS to import all the shapefiles in a certain folder
> (I've tried *.shp but it didn't work), and give each output map the same name
> as the original shapefile?
> Cheers,
> Márcia
> A. Márcia Barbosa
> Dept. Biological Sciences, North 2.1
> Imperial College at Silwood Park
> Ascot, Berkshire SL5 7PY
> United Kingdom
This mail was sent through http://webmail.uni-jena.de
