[GRASS-user] Determining number of overlapping features per
location after import of shape file
Rainer M Krug
r.m.krug at gmail.com
Mon Jun 23 06:13:48 EDT 2008
Hi
I am importing a vector layer from a shape file as follow, and get the
warning below:
> v.in.ogr dsn=/home/rkrug/Documents/Projects/AlienSpread/data/input/ layer=fireHistory output=fireHistory --overwrite
WARNING: 703 areas represent more (overlapping) features, because polygons
overlap in input layer(s). Such areas are linked to more than 1
row in attribute table. The number of features for those areas is
stored as category in layer 2
I am aware of that, and I want to create a raster layer with the
number of features overlapping in each location. As I ultimately need
a raster layer, I thought to use the following, but I get the error
message below:
> v.to.rast input=fireHistory layer=2 output=mf use=attr column=category --overwrite
ERROR: Unable to get layer info for vector map
Why is that?
Is there another way of getting the number of overlapping features per cell?
Thanks
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Plant Conservation Unit
Department of Botany
University of Cape Town
Rondebosch 7701
South Africa
