[GRASS-user] Determining number of overlapping features per
location after import of shape file
Markus Neteler
neteler at osgeo.org
Mon Jun 23 15:08:57 EDT 2008
Rainer,
I suggest to try the snap parameters of v.in.ogr first. Maybe the SHAPE
file is full of gaps and slivers (commonly found, even in governmental
data).
*Small* snapping values might cure it. Be careful to not snap, say,
Africa to a triangle :)
Markus
On Mon, Jun 23, 2008 at 12:13 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> Hi
> I am importing a vector layer from a shape file as follow, and get the
> warning below:
> > v.in.ogr dsn=/home/rkrug/Documents/Projects/AlienSpread/data/input/
> layer=fireHistory output=fireHistory --overwrite
> WARNING: 703 areas represent more (overlapping) features, because polygons
> overlap in input layer(s). Such areas are linked to more than 1
> row in attribute table. The number of features for those areas is
> stored as category in layer 2
> I am aware of that, and I want to create a raster layer with the
> number of features overlapping in each location. As I ultimately need
> a raster layer, I thought to use the following, but I get the error
> message below:
> > v.to.rast input=fireHistory layer=2 output=mf use=attr column=category
> --overwrite
> ERROR: Unable to get layer info for vector map
> Why is that?
> Is there another way of getting the number of overlapping features per
> cell?
> Thanks
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Plant Conservation Unit
> Department of Botany
> University of Cape Town
> Rondebosch 7701
> South Africa
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080623/8bfe80c4/attachment.html
