[GRASS-user] New User Getting Started
Moritz Lennert
mlennert at club.worldonline.be
Wed Jun 25 05:24:53 EDT 2008
On 24/06/08 20:25, Brock Anderson wrote:
> Hi Folks,
> I'm new to GRASS, and I'm hoping somebody can give me some advice to get
> me started...
> I have two netcdf raster grids. One is seafloor age, the other is
> seafloor depth. The files both cover the same geographic area, although
> the grids are different resolutions.
> What I want to do is plot a simple x-y graph of seafloor age vs. depth,
> where each point in my graph represents the a seafloor age grid cell and
> the intersecting seafloor depth cell.
> Can this be done? Can anyone suggest some basic steps to get me
> started? No instruction is too basic for me -- this is my first day
> with GRASS. I have just installed GRASS (and R, just in case it's
> necessary), but otherwise I have no idea how to proceed.
I suppose your two files are georeferenced.
1) Create projected location using the "create new location
using...georeferenced file"
2) Import both files with r.in.gdal (File->Import raster maps->Multiple
formats with gdal)
3) Several possibilities for extracting your information
- Use 'r.stats -n1 input=Age,Depth' to extract the values pixel by
pixel (use the command line as this can crash your GUI if you have large
images);
- Use r.coin (Raster -> Reports and statistics-> Mutual category
occurrences (coincidence)) to get the matrix of coincidence;
- You also have r.regression.line to calculate the regression
coefficients between the two, and r.covar to calculate
covariance/correlation coefficients.
4) Use whatever graphics software you want to make a graph out of this
information
