[GRASS-user] Connect point to point
leonidas300 leonidas_liakos at yahoo.gr
Fri Jun 27 01:48:54 EDT 2008
I have a shapefile with points. I need to create a second shapefile (based on
the first shapefile) which will contain lines connecting each point with
each other one by one (point 1 with 2 (one line), 1 with 3 (second line), 1
with for 4, 2 with 3 ...an so on). Is there any way to implement it with
GRASS? I don't know C or script language so I look for a tool.Thank you,
Leonidas
View this message in context: http://www.nabble.com/Connect-point-to-point-tp18069225p18069225.html
Sent from the Grass - Users mailing list archive at Nabble.com.
