[GRASS-user] Connect point to point
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Jun 27 04:37:53 EDT 2008
On Thu, 2008-06-26 at 22:48 -0700, leonidas300 wrote:
> I have a shapefile with points. I need to create a second shapefile (based on
> the first shapefile) which will contain lines connecting each point with
> each other one by one (point 1 with 2 (one line), 1 with 3 (second line), 1
> with for 4, 2 with 3 ...an so on). Is there any way to implement it with
> GRASS? I don't know C or script language so I look for a tool.Thank you,
> Leonidas
Not sure but maybe v.distance or m.cogo (in the GIS-Manager under File >
Bearing/distance to coordinates) maybe?
You might find some scripting ideas/solutions in the mailing list's
archive:
http://www.nabble.com/-GRASS-user--displaying-lines-between-given-points-td5691239.html#a5691239
http://www.nabble.com/Can-I-connect-the-dots-----td8612121.html#a8612121
http://www.nabble.com/-GRASSLIST%
3A4199--connect-the-dots-td8626816.html#a8626818
Nikos
