[GRASS-user] Connect point to point
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Jun 27 05:41:24 EDT 2008
On Thu, 26 Jun 2008, leonidas300 wrote:
> I have a shapefile with points. I need to create a second shapefile (based on
> the first shapefile) which will contain lines connecting each point with
> each other one by one (point 1 with 2 (one line), 1 with 3 (second line), 1
> with for 4, 2 with 3 ...an so on). Is there any way to implement it with
> GRASS? I don't know C or script language so I look for a tool.Thank you,
> Leonidas
v.net.visibility might possibly do what you want, or at least give you a
good starting point that can be edited further.
