[GRASS-user] Connect point to point
leonidas300
leonidas_liakos at yahoo.gr
Fri Jun 27 06:04:26 EDT 2008
Thank you for your help! I think that I should study some kind of programming
to accomplish some tasks for my job. How can I iterate through the shapes of
a vector map or the values of fields of an attribute table?Is there any
programming language for batch processing in Grass GIS? I have some Python
skills.Can I use it for batch processing with Grass? Are there any tutorials
or documentation for batch processing jobs and scripting for Grass?
That's exactly what I need to do:
http://www.ian-ko.com/ET_GeoWizards/UserGuide/connectPoints.htm
Paul Kelly-4 wrote:
> On Thu, 26 Jun 2008, leonidas300 wrote:
>> I have a shapefile with points. I need to create a second shapefile
>> (based on
>> the first shapefile) which will contain lines connecting each point with
>> each other one by one (point 1 with 2 (one line), 1 with 3 (second line),
>> 1
>> with for 4, 2 with 3 ...an so on). Is there any way to implement it with
>> GRASS? I don't know C or script language so I look for a tool.Thank you,
>> Leonidas
> v.net.visibility might possibly do what you want, or at least give you a
> good starting point that can be edited further.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Connect-point-to-point-tp18069225p18151912.html
Sent from the Grass - Users mailing list archive at Nabble.com.
