[GRASS-user] r.resamp.rst
Philipp Steigenberger
userlist at online.de
Wed Mar 5 09:00:56 EST 2008
christian Brandt schrieb:
> Dear list,
> using the r.resamp.rst to resample the resolution of my DGM-raster gave me the following result:
> "change region temporarily to desired resolution...
> change again to the original-region...
> Percent complete:
> dnorm in ressegm after grid before out2= 1329.287217
> dnorm in mainc after grid before out1= 1329.287217
> dnorm in mainc after grid before out2= 1329.287217
> Temporarily changing the region to desired resolution...
> Changing the region back to initial...
> r.resamp.rst completed. "
> I look forward to get some possibilites about how to get my desired resolution.
> Regards
> Chris
Christian,
Could you tell us the command-line you used?
you can also use r.resample and change the desired resolution manually
with g.region (see man r.resample)
cheers
Philipp
PS: You aren't the boyfriend of Ulle... are you???
